Alpha Material
Updated: 12 May 2025
Add a basic transparent material using a alpha blending.
This node generates a basic transparent material using an alpha blend.
| Colour | The colour of the material. |
| Brightness | How much light the object absorbs and doesn’t reflect back into the scene. |
| Specular Intensity | Intensity of the specular reflections |
| Specular Colour | The colour of specular light reflected from the material. |
| Colour Map -> Specular Colour | Use the input colour map as the specular reflection colour. |
| Specular Anisotrophy | Change the shape of the specular highlight. |
| Metallicness | Change how metallic the object looks. |
| Roughness | How rough the surface of the material is. |
| Normal Map Mode |
| Emissiveness | How much of a glow is emitted around the object. Requires “high dynamic range” to be turned on in the root. |
| Emissive Scattering | Controls how much Emissive lighting is scattered in the scene. |
| Opacity Mode |
Controls the opacity mode of the material, and how it blends with the scene.
| Alpha | Set the alpha amount of the material |
| Blend Mode | Change how the material once added to an object blends with the scene. Only functions with Alpha Mode for details. |
| Alpha Sort Bias | Biases the alpha sort in order to make it render in front or behind other transparent objects. |
| Output Alpha In GBuffer Composite | Sends the alpha to the gbuffer composite pass. |
| Translucency |
| Absorption | How much light is absorbed by the material as light passes through it. |
| Diffuse Lightmap | Enables an input diffuse lightmap for the material. |
| Diffuse Map | Specifies the color of light that scatters off the surface in all directions. It is functionally similar to the Colour Texture and is a core component of a material’s appearance. |
| Emissiveness Map | Determines which parts of a material appear to glow or emit their own light. Brighter values cause the surface to act as a light source. |
| Metallicness Map | A grayscale map to define how ‘metal-like’ a surface is. White values represent pure metal, while black values represent non-metals. |
| Alpha Map | A grayscale map that controls the transparency of the material. Black areas are fully transparent, white areas are fully opaque, and gray values create semi-transparency. |
| Ambient Occlusion Map | Adds subtle, soft shadows to areas that are occluded from ambient light, such as creases and crevices. This enhances realism and adds perceived depth to the model. |
| UV Texture Filter Mode |
| Diffuse Map -> AO |
A setting to use the Diffuse or Colour map to contribute to the Ambient Occlusion calculation, often darkening areas based on the base color.
| Diffuse Map UV | Select the UV for the Diffuse Map Texture. |
| Emissiveness Map UV | Select the UV for the Emissiveness Map Texture. |
| Metallicness Map UV | Select the UV for the Metallicness Map Texture. |
| Alpha Map UV | Select the UV for the Alpha Map Texture. |
| Ambient Occlusion Map UV | Select the UV for the Ambient Occlusion Map Texture. |
| Subsurface Colour Map UV | Select the UV for the Subsurface Colour Texture. |
| Subsurface Weight Map UV | Select the UV for the Subsurface Weight Texture. |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
| Lit |
Determines if the material is affected by lights in the scene. When disabled, the material appears fully lit by its own colour and texture, regardless of scene lighting.
| Shadows |
| Reflections Mode |
| Raytracing Settings |
| Polygon Sidedness |
| Vertex Colours - Apply To Alpha | Set how the vertex colours apply to the alpha of the mesh. |
| Vertex Colours - Apply To Metallicness | Set how the vertex colours apply to the metallicness of the mesh. |
| Vertex Colours - Apply To Emissiveness | Set how the vertex colours apply to the emissiveness of the mesh. |
