Sound Texture
Sound Texture
Updated: 12 May 2025
Generates an image based on the sound an audio source.
This node generates a texture based on the sound from either a selected or input audio source. The generated texture can then be modified using the same Attack/Decay tools as a sound modifier.
Sound Sound file used to drive the effect.
Looping Control whether the sound loops once it ends
Channel Which audio channel is used.
Band EQ Selects and weights the frequency bands to be used from the sound file.
Time Offset Offset the time the clones are modified from the time the waveform is at.
Change Threshold Changes the threshold for what counts toward the effect.
Attack Controls the initial time between the current values to the peak.
Min Value Acts as a minimum threshold for extracting a range of values from the waveform.
Max Value Acts as a maximum threshold for extracting a range of values from the waveform.
Max Clamp A maximum value which values will be clamped if they go above.
Spikiness Accentuates peaks in the waveform so they are sharper.
Scale How much the output values are scaled.
Offset Offset all values output by the texture.
Smoothness How much smoothing is applied between differing values.
Decay Buffer Size Size of the buffer used for sourcing the decay
Falloff Range Range in which the sounds data will be tracked.
Waveform Visualises the waveform of of the sound.
SoundUse an input sound to override the sound attribute.Sound Loader
