Distortion Deformer
Distortion Deformer
Updated: 3 Feb 2025
Deforms geometry based on a distortion function
This node deforms a mesh based on a distortion function, creating noisy and glitchy effects.
  • Local : Deformations are calculated in the Local Space of the object, so transformations of the parent mesh will not affect the deformation.
  • World : Deformations are calculated in the World Space of the scene, so transformations of the parent mesh will apply the deformer differently depending on the mesh position.
Noise Scale The amount of noise that is applied to the deformer.
Sine Scale Scale the sine wave used in the deformer.
Distort Y Scale How much the mesh is distorted along the Y axis.
Animation Speed Speed the deformer is animated at.
Mask ImageUse an image to mask out areas for the deformer to not function.Video Loader
