Curl Noise Deformer
Updated: 3 Feb 2025
Deforms geometry based on a curl noise functionUpdated: 3 Feb 2025
Deforms geometry based on a curl noise functionThis node deforms a mesh based on a curl noise function, creating noisy displacement and somewhat random looking shapes.
| Weightmap | Add a weight map to determine where the deformer is more or less effective. |
| Apply Mode |
Choose whether the deformer applies to the individual vertices or the mesh chunks.
| Transform Space |
Choose which transform space the deformer uses for deformation. Does not affect falloffs.
| Displacement Direction |
Change the direction the deformer displaces the mesh.
| Blend Amount | Global override for how much the deformer affects the mesh. |
| Displacement Amount | How much the deformer displaces the original mesh. |
| Noise Scale | Scale the size of the generated curl noise. |
| Animation Speed | Change the speed the deformer is simulated at. |
| Time Mode |
How the deformer updates with relation to the timecode.
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
| Mask Image | Use an image to mask out areas for the deformer to not function. | Video Loader |
| Generated Weightmap | Add a weightmap to vary the strength of the deformer across the surface. | Generate Weightmap |
