Turbulence Effector
Updated: 8 Jan 2026
Modifies a cloner system with turbulent motion.
Updated: 8 Jan 2026
This node applies an animating turbulence to the transforms of clones, with animation and scale parameters to tweak the size and shape of the noise to the desired behaviour.
| Blend Amount | Controls the amount the resulting transforms of each clone after the effector is applied is blended with the original transform. |
| Space |
The transform space the Effector uses to influence the clones.
| Num Octaves | How many time the noise generation is iterated. |
| Lucanarity | How large the gaps between larger areas of noise are. |
| Gain | The overall smoothness of the generated fractal noise. |
| Noise Scale | Scale the size of the generated fractal noise. |
| Limit Noise Range | Set the min and max range of the fractal noise values. |
| Animation Rate | The speed at which the fractal noise is animated. |
| Update Time Mode |
Change how the clone animation uses time.
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
| Selection Mode |
Set the mode for Index-Based Weighting.
| Selection Operation |
Set how you want top define the selection.
| Index | The first clone index in the range. |
| Max Index | The last clone index in the range. |
| Index Step | The increment used in “Step” mode. |
| Index Seed | The seed used in “Random In Range” mode. |
| Index Falloff Range | Falloff amount for Index-Based Weighting. |
| Index Falloff Power | The curve power of the falloff for Index-Based Weighting. |
| Position X | Offset the clones x position from the current position. |
| Position Y | Offset the clones y position from the current position. |
| Position Z | Offset the clones z position from the current position. |
| Rotation Heading | Offset the clones y rotation from the current rotation. |
| Rotation Pitch | Offset the clones z rotation from the current rotation. |
| Rotation Bank | Offset the clones x rotation from the current rotation. |
| Scale X | Offset the clones x scale from the current scale. |
| Scale Y | Offset the clones y scale from the current scale. |
| Scale Z | Offset the clones z scale from the current scale. |
| Uniform Scale | Uniformally scale the clones by the same value along all axes. |
| Object Index | Offset the clone’s index from the current clone index. Used to select which child object of the cloner is cloned where. |
| Apply To Position | Apply the position changes from the effector to the clones. |
| Apply To Rotation | Apply the rotation changes from the effector to the clones. |
| Apply To Scale | Apply the scale changes from the effector to the clones. |
| Apply To Object Index | Apply the object index changes from the effector to the clones. |
| Position Apply Direction |
The direction that the effector applies positions to the clones.
| Position Apply Mode |
The method by which the effectors position properties are applied to the clone. Affecting the previously applied position values.
| Rotation Apply Mode |
The method by which the effectors rotation properties are applied to the clone. Affecting the previously applied rotation values.
| Scale Apply Mode |
The method by which the effectors scale properties are applied to the clone. Affecting the previously applied scale values.
| Object Index Apply Mode |
The method by which the effectors object index properties are applied to the clone. Affecting the previously applied object index values.
| Uniform Random Scale | Uniformally scale the clones by the same value along all axes. |
| Procedural Falloff | Use a procedural system to generate falloff from. Useful for creating complex and unconventional falloffs from an Effector. | Procedural Root |
