Curve Remap Modifier
Updated: 9 Jan 2026
Remaps a modifier's value based on a curve
This node takes the value of a modifier and remaps its value based on a customisable curve. The node takes the input value, moves along the curve by that amount, and then outputs the value at that point on the curve.
Current Value Shows the current value of the effect. Cannot be directly changed.
Curve Programmable curve used to calculate the remapped output.
Blend Amount Control how much the modifier affects the values its input into.
In Scale Multiplies the incoming value by this amount before being used by the node.
In Offset Adds this amount to the incoming value before being used by the node.
Out Scale Multiplies the curve output by this amount.
Out Offset Adds this amount to the curve output value.
This node has no inputs.
