Render To Surfaces
Render To Surfaces
Render the connected nodes onto object surfaces.
This node renders connected objects and lights onto the surface of chosen objects.
Width Width of rendered texture.
Height Width of rendered texture.
Background Colour Change the background colour of the rendered texture.
Disable Render To Texture (Pass Through) When enabled, the texture rendering will be ignored and the child nodes will be passed through into the main scene.
Use 360 Degree Camera Render onto surfaces using a 360 degree camera mapping.
Target SurfacesSelect which surfaces will have the rendered image applied to them.3D Object
Rendered NodesAdd nodes which will be included in the rendered scene.3D Object
Affecting LightsChoose which lights will affect connected objects.Light
Excluded LightsChoose which lights wont affect connected objects.Light
