Curve Remap
Updated: 26 Jan 2026
Remaps a modifier's value based on a curve.Updated: 26 Jan 2026
Remaps a modifier's value based on a curve.This node takes the value of a modifier and remaps its value based on a customisable curve. The node takes its input value, moves along the curve by that amount, and then outputs the value at that point on the curve.
In each curve, the horizontal axis represents input values and the vertical axis represents output values. By default, the curve is a straight diagonal line from bottom left to top right, meaning input values are mapped directly to output values with no change. By editing the curve you can affect the relationship between input and output values at any point along the curve.
Double LMB in the curve editor to add a point.
Double LMB on an existing point to delete it.
| Value | Base value to modify the output value with. |
| Curve | Programmable curve used to calculate the remapped output. |
| Blend Amount | Control how much the modifier affects the values its input into. |
| In Scale | Multiplies the incoming value by this amount before being used by the node. |
| In Offset | Adds this amount to the incoming value before being used by the node. |
| Out Scale | Multiplies the curve output by this amount. |
| Out Offset | Adds this amount to the curve output value. |
| Operation |
This node has no inputs.
