Particles To Point Geometry
Updated: 14 Jan 2026
Renders particles as raytraced spheres.
This node renders a raytraced sphere for all particles. Although it is not geometry like a primitive, the sphere will correctly simulate lighting and material shading the same way as a 3D object, and a Material node can be added for greater control.
For a particle system that only needs small points or spheres, this node can be faster and higher quality. for a wide variety of shapes, use the Particle Cloner node.
Emissive Materials can be connected, but will not emit lighting. If needed, look at a Particle Cloner workflow instead.
| Particle Use Amount | Percentage of particles that can be used by the node. |
| Point Size | Edit the size of the particles once they are rendered. |
| Point Size Randomness | Control the randomness in size of the particles. |
| Luminance | Control the luminance of the rendered particles. |
| Luminance Randomness | Control how much randomness is in the luminance of the rendered particles. |
| Seen By Rays | Allow the mesh to be seen by the raytracer. When set to 0, the mesh will still render in camera but will be ignored by any raytracing nodes. |
| Material | Add a material to override the internal default material. | Material |
| Rendered Emitters | Specify which emitters are rendered using this renderer. By default, all emitters connected to the same particle root as the renderer are rendered. | Primitive Emitter |
