Emissive Material
Emissive Material
Updated: 4 Nov 2024
Add an emissive material.
This node generates a basic emissive material, similar to the default material node but without any specular settings.
  • Off : Disables the use of the diffuse map for AO.
  • On : Enables the use of the diffuse map for AO.
  • Off : Disables lighting; the material displays its base colour only.
  • On : Enables the material to be affected by scene lighting.
This node has no inputs.
