Blend Materials
Updated: 12 May 2025
Mix multiple materials together into one material.Updated: 12 May 2025
Mix multiple materials together into one material.This node allows the combination of various materials to form one complex blended material. An input image or Shading node can then be used to control transitions and blends between materials based on the value of the mask source.
These properties control the blending of materials.
| Alpha | Value to blend through the input materials. |
These properties control attributes of the material.
| Displacement Offset | Adds an initial offset to the displacement. |
| Displacement - Use Polygon UVs | TBC |
These properties allow textures to modulate the surfaces. Textures connected to the materials relevant input properties will overwrite these textures.
| Alpha Map | A grayscale map that controls the transparency of the material. Black areas are fully transparent, white areas are fully opaque, and gray values create semi-transparency. |
| UV Texture Filter Mode |
| Alpha Map UV | Select the UV to use for the alpha map. |
| Texture Wrap Mode U |
| Texture Wrap Mode V |
These properties control how the material interacts with lighting.
| Lit | Determines if the material is affected by lights in the scene. When disabled, the material appears fully lit by its own colour and texture, regardless of scene lighting. |
| Shadows |
Defines how the object interacts with light in the scene.
| Raytracing Settings |
These properties control how the material interacts with the properties of the geometry it is applied to.
| Polygon Sidedness |
| Materials | Input for materials that you want to blend. | Material |
