Web / HTTP API
Notch Blocks and Standalone Executables provide a web-server that allows exposed properties to be controlled via HTTP GET requests. This functionality primarily drives the Web GUI, but can also be used by 3rd party applications & web services.
To enable the Web API follow the instructions for enabling the Web GUI.
All calls listed below should be made via:
e.g. http://127.0.0.1:8910/control
Calling /control will return a JSON manifest of the exposed properties. An example below:
"controls": [
"enums": [
"Deferred Lighting"
"groupName": "",
"name": "Notch Layer",
"type": "Enum",
"uniqueId": "layerlayerlayer",
"value": ""
"groupName": "3D Object",
"max": 1.964810013771057,
"min": 0,
"name": "Position X",
"type": "Float",
"uniqueId": "Position X::Transform::ee54699e-8bc2-11e6-895a-002590e7589b",
"value": "1.964810"
"protocolVersion": "100"
The Layer attribute will always be shown in the manifest.
To set an Exposed Properties value call: /control?uid=<your_uniqueid>&value=<your_value>
/controluid: The uniqueId (URL escaped) as provided by the JSON manifest (above) and viewable in the Notch Builder when you exposed the property.value: The value you wish to set. If setting text strings, then URL escape the string.Examples:
| Param Type | URL Syntax |
| Text | http://127.0.0.1:8910/control?uid=Text+String%3A%3AAttributes%3A%3A7f9b7203-30d8-11e7-b0fa-b88a60f6d91a&value=Hello%20World |
| Float | http://127.0.0.1:8910/control?uid=Position+X%3A%3ATransform%3A%3Aee54699e-8bc2-11e6-895a-002590e7589b&value=0.6955427448749542 |
| Colour (RGBA) | http://127.0.0.1:8910/control?uid=Colour%3A%3AMaterial%3A%3Afb679e90-8bc2-11e6-895a-002590e7589b&value=0.1881285057810822%2C1%2C0.30517378671806084%2C1.000000 |
