Colour And Depth Source
Updated: 22 Mar 2024
Combines two input images and generates a depth camera source from them.Updated: 22 Mar 2024
Combines two input images and generates a depth camera source from them.This node is similar to the Depth Camera / Kinect Source node, but instead combines two input images and generates a depth camera source from them. This can then be used with some of the other Depth Camera / Kinect nodes, such as the Depth Camera / Kinect Mesh.
| Preview In Viewport |
| Apply PostFX Before Alpha Image Input (Legacy) | When enabled, the alpha input image is applied after the postfx pass, overwriting any effects the postfx would have applied to the alpha channel. |
| Near Clip Plane | The closest distance that will be rendered. WARNING: Reducing this value too low can reduce the accuracy of aspects of the render. |
| Far Clip Plane | The furthest distance that will be rendered by this camera. WARNING: Increasing this value too high, without increasing the Near Clip can reduce the accuracy of aspects of the renderer. Generally best left untouched. |
| Depth Clip Hardness | How harsh the falloff is for depth data. |
| Colour Image Offset X | Manually align the colour image to the depth horizontally. |
| Colour Image Offset Y | Manually align the colour image to the depth vertically. |
| Output Depth | Toggle whether only the depth image is output. |
| Colour Source | Source colour image to be used. | Video Loader |
| Depth Source | Source depth image to be used. | Video Loader |
| Effect Mask | Mask out areas that Post-FX applied to this node won’t be applied. | Video Loader |
| Alpha Image | Use a separate video nodes luminance values to overwrite the alpha channel of the image. | Video Loader |
