Text String
Updated: 2 Sep 2025
Editable Text String.
Updated: 2 Sep 2025
This node can be used to represent a text string, which can be used to input text into other nodes - typically the Text node or string manipulation nodes such as Merge Text and Split Text.
| Text | Text string to be used as a source in another node. |
