Split Text
Updated: 20 Jan 2026
Split a text strings from a seperator.
This node splits text strings into an array, then using the index parameter one can be used as an input into other nodes - typically the Text node or to be processed by other text string nodes.
| Text | Overwrite the text string attribute with an input text string. |
| Separator | character used to split text up by. |
| Output Split | the index in the new array of text to output from. |
| Text Strings | Overwrite the text string attribute with an input text string. | Text String |
