Procedural Meshing
Updated: 13 Dec 2024
Renders a procedural system as geometry.
Generates a surface from a procedural by first voxelising it, and then constructing a smoothed surface over the voxels. The surface produced is a triangle mesh which can be textured, deformed, can cast shadows, and can be used as a particle emitter among other things.
| Grid Width | Width of the adaptive voxel grid. |
| Grid Height | Height of the adaptive voxel grid. |
| Grid Depth | Depth of the adaptive voxel grid. |
| Update Mode |
Set how the procedural system updates.
| Error Tolerance | If the procedural distance field has too much distortion then it may be necessary to raise the error tolerance. a higher error tolerance may reduce performance, so this is a trade-off. |
| Adaptive Subdivisions | Amount of subdivisions to apply to the mesh.Can be used to smooth out the mesh. |
| Smoothing Iterations | Iteratively smoothes the meshes vertices by the number of levels specified, averaging out all the vertices in the mesh and producing a smoother result. Smoothing is done before rendering. High values can impact performance greatly, and may not be temporally stable if the underlying mesh changes. |
| HQ Smoothing | When enabled, vertex positions will be projected back on to the procedural surface. this preserves sharp edges without increasing the voxel grid size. |
| Distance Field Normals | Vertex normals will be extracted from the procedural distance field. this can be more accurate, but slower. |
| Seal Boundaries | When a procedural intersects the bounding box, usually a hole is created. enabling this option will fill in the hole. |
| Generate Colours | Uses colours set in procedural nodes (such as 3d primitive) to colourise the generated vertices. this can reduce performance slightly. |
| Generate UVs | Generate texture coordinates at the generated vertices, for use with a material. this can reduce performance slightly. |
| Seen By Rays | Allow the mesh to be seen by the raytracer. When set to 0, the mesh will still render in camera but will be ignored by any raytracing nodes. |
| Show Metrics | Displays information about the amount of mesh geometry being generated. |
| Procedural Root | Use a Procedural Root as an input, so the renderer is treated separately from the roots transforms. In this case, the renderer itself would be connected to the scene Root node. | Procedural Root |
| Render Transform | Takes the transformation of another node and applies it to the rendered mesh. | Null |
| Material | A material to apply to the rendered mesh | Materials |
| Bounding Box | The region in which the surface will be voxelised and generated | Bounding Box |
