Voronoi Node
Voronoi Node
Updated: 22 Mar 2024
Generates a 3D Voronoi pattern for procedurals.
Generates a 3D Voronoi pattern based on an input particle system. If no particle root is plugged in, then a default infinite pattern will be used.
Num Particles Number of particles to be used to generate the voronoi shape.
Mode Select how the voronoi points are sourced.
  • Grid : Points of generated grid will be used. this can be scaled and moved using the transformation values.
  • Particles : The particles in a particle system are used for the voronoi points. this requires a particle root or particle emitter to be connected.
Particle NodeConnect a particle system to generate the procedural shape.Particle Root
