Spline
Updated: 30 Sep 2025
Generates a 3D Spline for ProceduralsUpdated: 30 Sep 2025
Generates a 3D Spline for ProceduralsThis node generates a distance field from an input Spline. The input spline can be modified via their control points, and the procedural spline will dynamically update to match.
A mesh can be used as input if it has the Object To Lines deformer. The Duplicate Spline deformer can also be used to easily draw multiple splines.
| Thickness | The thickness of the generate spline. |
| Spline Time Min | The start point of the SDF along the length of the spline, by a value normalised by the splines length. |
| Spline Time Max | The end point of the SDF along the length of the spline, by a value normalised by the splines length. |
| Spline Time Offset | Offset the SDF by a value normalised by the splines length. When used with the Spline Time Min and Spline Time Max, can deform the mesh along the spline. |
| Generate Colours | Takes the colours from the original Spline and passes them into the SDF colour channel. Has no affect when Affect Colour is disabled. |
| Generate UVs | Generate texture coordinates in the SDF, for use with Materials. Can reduce performance slightly. |
| CSG Mode |
These options change how a this procedural node combines with the existing of the procedural system.
| CSG Blend Weight | How much the new procedural blends with the old procedurals, depending on the CSG Blend Weight. |
| CSG Stair Count | How many steps in the transition when using the “Stairs” CSG Mode. |
| Affect Colour | Affect the colour of the generated procedural system. only functions with ‘Generate Colours’ enabled in some Procedural Render nodes. |
| Always Enabled (No Time Bars) | When enabled, this node will run regardless of time bar enable/disable. Due to how Notch handles shader generation with procedurals, with this enabled the node runs more efficiently. |
| Material Colour | Modify the colour for the procedural material. |
| Custom CSG Code | Type your Custom code here, using the HLSL language. Read more on Editable Code. |
| Spline | The spline to use to generate the procedural. | Spline |
