Reaction-Diffusion
Updated: 7 Oct 2025
Performs reaction-diffusion simulation to a Procedural system.
Updated: 7 Oct 2025
Performs reaction-diffusion simulation, using a procedural input to restrict the placement of seeds and another procedural input to restrict growth.
This node simulates the Gray-Scott reaction-diffusion process, which can be thought of as a kind of fluid simulation with an extra step that creates organic-like patterns which grow out from seed points. Seed points are created by random spread, and if a seed restrictor is used then seeds outside of the restrictor volume are rejected. The growth is limited by the growth restrictor volume.
More information on the general topic of reaction-diffusion simulation can be found here.
| Distance Offset | Offsets the distance field values, causing the generated distance field to expand of contract. |
| Filled Mode | Thickness of the Shell wall, when Filled Mode is set to Shell. |
| Shell Thickness | Thickness of the Shell wall, when Filled Mode is set to Shell. |
| Simulation Grid Width | The voxel width resolution of the simulation grid used for performing the reaction-diffusion simulation |
| Simulation Grid Height | The voxel height resolution of the simulation grid used for performing the reaction-diffusion simulation |
| Simulation Grid Depth | The voxel depth resolution of the simulation grid used for performing the reaction-diffusion simulation |
| Initialisation Seed | The randomisation of the seed points can be changed by changing this seed value |
| Smoothen | When enabled, the surface extracted from the simulation is smoothened internally |
| Growth Pattern | Changes the type of growth that occurs. at 0.0 the growth will be more like a web, and at 1.0 the growth will be more like separated blobs. |
| Growth Rate | Controls the speed at which the growth progresses. |
| Invert Growth Restriction | Inverts the inside/outside sense of the restriction volume. |
| Invert Seed Restriction | Inverts the inside/outside sense of the seed volume. |
| Seed Density | Increase this property to make the seed points appear more densely packed together. decrease it to spread them out more. |
| CSG Mode |
These options change how a this procedural node combines with the existing of the procedural system.
| CSG Blend Weight | How much the new procedural blends with the old procedurals, depending on the CSG Blend Weight. |
| CSG Stair Count | How many steps in the transition when using the “Stairs” CSG Mode. |
| Affect Colour | Affect the colour of the generated procedural system. only functions with ‘Generate Colours’ enabled in some Procedural Render nodes. |
| Always Enabled (No Time Bars) | When enabled, this node will run regardless of time bar enable/disable. Due to how Notch handles shader generation with procedurals, with this enabled the node runs more efficiently. |
| Material Colour | Modify the colour for the procedural material. |
| Custom CSG Code | Type your Custom code here, using the HLSL language. Read more on Editable Code. |
| Growth Restrictor | Restrict the growth rate. | 3D Primitive |
| Bounds Override | Override the bounds. | Bounding Box |
| Seed Restrictor | Restrict where seed values can be positioned. | 3D Primitive |
