Fractal Noise
Fractal Noise
Updated: 22 Mar 2024
Generates 3D fractal noise for a Procedural system.
This node generates 3D fractal noise for a procedural system, useful for cutting into an existing shape with the CSG modes or generating randomised areas of falloff for a Cloning Effector.
Num Iterations The number of octaves of noise. a higher value will produce more detail.
Fractal Mode Which fractal noise generation method to use.
  • 3D Fast Noise : A simple and fast noise generation.
  • 3D Noise : A more complex noise generation method, which looks nice but is a bit slower.
  • 4D Noise (Time-Evolving) : 3d noise, but with an added dimension so the noise can be animated.
  • 3D SDF Noise : .
  • 3D SDF Simplex Noise : .
Lacunarity How large the gaps between the generated noise is.
Gain The smoothness of the generated noise.
Animation Rate The speed at which the noise is animated.
Update Time Mode How the node updates with relation to the timecode.
  • Locked To Timecode : The node’s animations are locked to the timecode and the same time will always yield the same result.
  • Running / Loopable : The node’s animations are disconnected from the timecode and will run seamlessly at the end of the composition.
Transform ControllerSet the origin/center point of the noise.Null
