Turbulence Warp
Updated: 19 Feb 2025
Warps an image with a turbulence.
This node warps an image with a turbulence of the screen.
| Displacement Amount | How much the warp effect displaces the image. |
| Noise Scale | Scale the size of the generated fractal noise. |
| Lacunarity | How large the gaps between larger areas of noise are. |
| Gain | The overall smoothness of the generated fractal noise. |
| Edge Fade Distance | Fades the amount the effect has on the texture from th edges inwards. |
| Falloff Range | Limit the range from which the warp falls off an becomes ineffective. |
| Animation Rate | Control the speed at which the noise is animated. |
| Update Time Mode |
How the effect updates with relation to the time code.
| Falloff Node | Add a gradient that controls how far the effect affects the image. | Gradient 2D |
| Mask Image | Add an image which controls areas which are not affected by the warp effect, using the images luminance. | Image Plane |
