Sine Warp
Updated: 19 Feb 2025
Warps an image with a ripple emanating from the centre of the screen.
This node warps an image with a ripple emanating from the centre of the screen.
| Sine Major Scale Axis | Change the peak value for the major axis of the sine wave. |
| Sine Minor Scale Axis | Change the peak value for the minor axis of the sine wave. |
| Displacement Amount | How much the warp effect displaces the image. |
| Noise Amount | How much is applied to the warp. |
| Falloff Range | The range at which the effect works. |
| Max Displacement | Maximum amount the image can be displaced. |
| Animation Rate | Change the rate at which the sine wave is animated. |
| Update Time Mode |
How the effect updates with relation to the time code.
| Falloff Node | Add a gradient that controls how far the effect affects the image. | Gradient 2D |
