Randomise Tiles
Updated: 11 Nov 2025
Randomise parts of the image based on an input image.
This node breaks the image into a grid, and randomises the positions and frame delays of parts of the image based on an input image.
The processed texture above has been altered from default to show the kind of effect you can get with this node. By default, no change will be made to the node until you input an image.
| Use Num Tiles | Toggle whether the tiles are generated based on size, or based on numbers that fit into the viewport. |
| Tile Size X | Width of the tiles generated. only functions with use num tiles toggled off. |
| Tile Size Y | Height of the tiles generated. only functions with use num tiles toggled off. |
| Num Tile X | Number of tiles generated along the x axis. only functions with use num tiles toggled on. |
| Num Tile Y | Number of tiles generated along the y axis. only functions with use num tiles toggled on. |
| Gap Width | Width of the gap between the tiles. |
| Randomisation X Range | The x range at which a tile can be randomly moved to. |
| Randomisation Y Range | The y range at which a tile can be randomly moved to. |
| Use As Absolute Positions | Use the absolute positions of the tiles in the grid, rather than relative offsets. |
| Delay Range | Sets the range of delay of the “Delay Offset Image” input texture. |
| Show Offsets | Visualise how the image is being offset based on the tile input. |
| Randomisation X Image | Randomise the image along the x axis based on the luminance values from an input image. | Video Loader |
| Randomisation Y Image | Randomise the image along the y axis based on the luminance values from an input image. | Video Loader |
| Delay Offset Image | Randomise the frame delay per tile based on the luminance values from an input image. | Video Loader |
