Droste Warp
Droste Warp
Updated: 5 Jun 2026
Applies a Droste function, creating an infinitely warping warp.
This node applies a Droste function to the image, creating an infinitely warping warp.
Animation Rate Change the rate at which the sine wave is animated.
Focal Point Offset X Move the centre point of the droste effect.
Focal Point Offset Y Move the centre point of the droste effect.
Matrix Coefs X Pinches and stretches the image inward.
Matrix Coefs Y Radial twist amount.
Matrix Coefs Z Shift the radial twist inward and outward.
Matrix Coefs W Stretch the image around the focal point.
Spiral Multiplier Multiply the radial twist, so it twists more
