Curl Noise Warp
Curl Noise Warp
Updated: 19 Feb 2025
Warps using a curl noise function.
This node warps and image using a curl noise function.
Noise Scale Size of the noise in the warp.
Falloff Range How far the falloff for the warp reaches.
Simulation Speed Control the speed at which the warp is animated.
Edge Fade Distance How much of the edge is effected by the warp from the center.
Mask ImageAdd an image which controls areas which are not affected by the warp effect, using the images luminance.Image Plane
