Voronoi Post Process
Updated: 5 Jun 2026
Add a Voronoi breakup effect to an image.
This node generates a Voronoi breakup of the image based on an input particle system, then applies an effect to the image by offsetting the image along a random vector.
Mode Changes how the voronoi diagram affects the image.
  • Reflection Warping : Use the voronoi triangles to simulate a glass-like reflection of the image.
  • Cell Colour : Sample a colour from the image for each triangle.
Warp Amount Changes how much the voronoi regions are displaced from the image.
Amount Changes how much the voronoi diagram affects the image.
Noise Distortion Distorts the output with noise.
Crack Amount How wide the cracks are between the voronoi regions.
Chromatic Aberration How much chromatic aberration affects the image.
Particle RootUsed to gather the points for the Voronoi region generation. The regions will then be drawn based on the particle positions in screen space.Particle Root
