Sharpen
Sharpen
Updated: 24 Feb 2025
Add a sharpen effect to the image.
This node raises the contrast along the edges of an image, increasing its sharpness. Useful for increasing the visibility of details in an image.
Amount Change how strong the efffect is on the input image.
Radius Increase the radius of the sharpen effect
Texture Wrap Mode U Select how the effect should apply to the edges of the image.
  • Wrap : Effect will attempt to blend with the opposite side, to create a repeating effect.
  • Clamp : Effect will complete at the edge, with no attempt to wrap.
Texture Wrap Mode V Select how the effect should apply to the edges of the image.
