Pixel Sort
Updated: 24 Feb 2025
Add a simple pixels sorting algorithm to the image.
This node analyses the image for its brightest areas, and sorts the pixels darker than this bright spot by luminance along a chosen axis.
| Brightness Threshold | Threshold below which values will be blended into the data mosh. |
| Mask Threshold | TBC. |
| Direction | Select which direction the pixels are sorted in. |
