Digital Block Glitch
Updated: 25 Mar 2025
Add an animated block glitch.
This node generated an effect of digital blocks periodically displacing the image and altering their colours.
Parameter | Details |
Active | Enables or disables the effect. Disabling the effect means it will no longer compute, so disabling a node when not in use can improve performance. |
Blend Amount | Changes the opacity of the new effect over the original image. |
Blend Mode (RGB) | Change how the generated effect blends with the parent image RGB. |
Blend Mode (Alpha) | Change how the generated effect blends with the parent image alpha. |
Block Size | Pixel size of the blocks the image will be broken into. |
Breakup Amount | How much the blocks are broken up. |
Breakup Frame Amount | How far apart the blocks are moved when breaking up. |
Breakup Size | How large each block is. |
Displace Amount | How much to displace the image when broken up. |
Glitch Rate | How often the glitch frames appear. |
Glitch Duration | How long the glitch frames last. |
Toggle which of the RGBA channels are affected by the effect.
