Median Filter
Updated: 20 Feb 2025
Add a noise reducing filter to the image.
This node performs a filter operation where the median colour in a region of pixels is taken as a result. Useful as a part of a larger de-noising process.
| Iterations (Effect Size) | How many times the effect is run. |
