Frame Delay
Updated: 25 Feb 2025
Add a Delay to a video.
This node delays the image played by a specified frame amount. It is also used as a generalised buffer for the Frame Delay Frame (which picks specific frames from the buffer).
| Num Delay Frame | Number of frames the image will be delayed by. Max 2500. |
| Buffer Format |
Select which format the buffered frames are kept in.
