Edge Detect
Updated: 20 Feb 2025
Detect the edges in an image.
This node evaluates an image to try and identify details and edges within. Useful for creating neon effects from a simple video image with a Glow node, or for highlighting edges of an image when in additive mode.
| Mode |
Change which edge detection method is used.
| Colour | Edit the colour of the edge |
| Threshold | Change the threshold for the edge detection. |
| Scale | Scale the brightness for the effect. |
| Width | Change the width of the output lines detected. |
| Pixel Width | When sobel mode is chosen pixel width defines the width of the edge. |
