Decompress UV Animation
Decompresses a compressed UV animation.
This node losslessly decompresses and therefore reverses the result of a Compress UV Animation node.
Mode Select how the uv animation is compressed - whether the result should use only the rgb channels of the output, or the alpha as well. this parameter must match the setting used on the compress uv animation node that created the source image.
