RGB Distortion
RGB Distortion
Updated: 5 Jun 2026
Add RGB sine distortion to an image.
This node applies multiple sine waves to distort the image, each corresponding to an RGB channel. The result is then further distorted with noise, to get a convincing distortion effect. Useful as a part of a digital glitch effect, simulating the RGB channels misaligning in a CRT display.
Red Distribution Distribution of red distortion.
Green Distribution Distribution of green distortion.
Blue Distribution Distribution of blue distortion.
Distort Y Distortion on the y-axis.
Sine Scale Scale of the sine wave.
Noise Scale Scale of the noise.
Speed Speed at which the distortion is animated.
Mask ImageUse a mask image to control where the output is most or least affected by the effect, based on the mask images luminance.Image Plane
