Rigid Body Procedural
Allows a procedural system to be used for collisions with rigid bodies.Updated: 4 Dec 2023
Allows a procedural system to be used for collisions with rigid bodies.The Rigid Body Procedural node allows a procedural system to be used as a collider for rigid bodies. It must be parented to a Rigid Body Root. This node is great for getting complicated physics interactions at high frame rates.
| Static Friction | How much resistance there will be for rigid bodies that are at rest relative to each other to begin moving. |
| Friction | How much other rigid bodies will be able to slide along side this rigid body. When two rigid bodies of different frictions interact, the minimum value is used. |
| Bounciness | How much this rigid body will bounce off of other rigid bodies in the scene. |
| Density | The density of the rigid body. The density is scaled by the area of the shape to determine the mass of the body. |
| Collision Radius | The radius of collision shape if applicable. |
| Collision Mode |
Mode for calculating collision if applicable.
| Procedural Root | The root node of a procedural system to use as a collision surface. | Procedural Root |
