Noise Shading
Updated: 14 Jan 2026
Shades particles using fractal noise.
This node shades particles using values generated by a fractal noise function, similar to the Fractal Noise Generator node but in 3D. The noise function may be sampled by the position of the particle in 3D, or the life of the particle. Useful for adding flickering effects to particles.
| Position X | Position x in local space |
| Position Y | Position y in local space |
| Position Z | Position z in local space |
| Rotation Heading | Rotation around y axis in local space |
| Rotation Pitch | Rotation around x axis in local space |
| Rotation Bank | Rotation around z axis in local space |
| Scale X | Scale along the x axis in local space |
| Scale Y | Scale along the y axis in local space |
| Scale Z | Scale along the z axis in local space |
| Num Octaves | How many time the noise generation is iterated. |
| Noise Scale | Scale the size of the generated fractal noise. |
| Animaton Rate | The speed at which the fractal noise is animated. |
| Lacunarity | How large the gaps between larger areas of noise are. |
| Gain | The overall smoothness of the generated fractal noise. |
| Intensity Scale | Scales the intensity of the resulting noise values. |
| Input Channel |
Choose how the noise affects the particles.
| Radius | Outer radius for which the particles will no longer be coloured. |
| Inner Radius | Inner radius for which the particles will be coloured at their max. |
| Falloff Power | How quickly the gradient changes from the inner radius to the outer radius. |
| Noise Colour | Change the colour of the particles as they spawn. |
| Blend Mode | Choose how the particle colours blend to the source colours |
| Blend Amount | Control how much the new shading affects the particles. |
| Position Node | Control the position of the fractal nose ion 3D space. | Null |
