Render Particles To Surfaces
Updated: 14 Jan 2026
Renders particles onto nearby Meshes.
This node renders particles onto nearby 3D surfaces. This means that instead of rendering particles directly into space, they instead appear as dots on 3D geometry, only being visible when they are within a certain proximity to 3D geometry. This is particularly useful when attempting to render particles in a scene rendered by a UV Camera. A spatial grid is used to evaluate the particles, so you may need to add a bounding box and adjust its scale to make sure the particles are evaluated correctly. Reducing the particle size is also a useful step for getting a reasonable quality result.
An image may also be used on the particles, by adding one to the Texture parameter. If an image is not used the sprites will render as a circle with falloff based on particle proximity. The alpha channel of a supplied image is also used to affect particle transparency.
Texture Select a texture to be rendered at each particles position.
Output Target Determines which channel the effect is rendered to.
  • Composite : Render particles to the final composite colour channel.
  • Baked Shadow : Render particles to the shadow channel, so they appear as shadows that darken the effect of lights on geometry.
  • Albedo : Render particles to the albedo colour channel so they appear as decals, with lighting applied on top.
Blend Mode Choose how the particle colours blend to the source colours
Particle Alpha Change the alpha value for the particles.
Particle Size Edit the size of the particles once they are rendered.
Size Randomness Control the randomness in size of the particles.
Particle X Scale Control the x-scale of the sprites emitted.
Particle Y Scale Control the x-scale of the sprites emitted.
Pixel Align Output Align the rendered points exactly to screen pixels, with no sub-pixel interpolation.
Particle Scale Coeffs How much the particle scales are affected by the node at different stages of the particle life. Values 1 and 2 are control points, and are used to control the curve between values 0 and 3.
Screen Size Limits The minimum and maximum size of the rendered particle in normalised screen coordiates.
Specify Size Limits In Pixels Indicates whether particle size limits are specified in normalised viewport coordinates which are consistent across different render resolutions, or in pixels.
Rotation Randomness Control how much randomness is in the rotation of the particles.
Rotation Follows Direction Toggle whether the rotation of the particles follows the direction the particle is moving in.
Motion Blur Amount Control the amount of motion blur.
Use Texture Animation Edit whether the texture animation is shown with the rendering.
Texture Animation Rate Edit whether the texture animation is shown with the rendering.
Num Frames X Change how many tiles the sprite image will be spread across the x axis.
Num Frames Y Change how many tiles the sprite image will be spread across the y axis.
Randomise Start Frame Randomises the beginning frame the texture animation is played from.
Bounds NodeThe bounding box within which particles are rendered.Bounding Box
