Dot Matrix Renderer
Dot Matrix Renderer
Updated: 13 Jan 2026
Renders particles as a dot-matrix in screen space.
This node renders particles in a dot-matrix like effect that aligns them to grid cells in screen space. Changing the grid size requires balancing the Dot Grid Size and Particle Size properties, where the particle size is ~1/2 of the grid size.
Texture Select a texture to be rendered at each particles position.
Particle Size Edit the size of the particles once they are rendered.
Particle Alpha Change the alpha value for the particles.
Dot Grid Size The size of the grid in cells in pixels.
Use Texture Animation Edit whether the texture animation is shown with the rendering.
Texture Animation Rate Change the speed the texture animation is played at.
Num Frames X Change how many tiles the sprite image will be spread across the x axis.
Num Frames Y Change how many tiles the sprite image will be spread across the y axis.
Randomise Start Frame Randomises the beginning frame the texture animation is played from.
Blend Mode Choose how the texture blends onto the particles.
