Volume Emitter
Volume Emitter
Updated: 15 Dec 2025
Emit particles that fill the volume of a mesh.
This node generates particles in a filled volume inside of an input 3D object. This requires that the input object is converted to a 3D signed distance field representation. Objects with animation or deformation are not supported. Useful for generating particles for fluid or physical simulations that need to be evenly spaced within a volume.
A 3D Object node must be connected to the Object Node input for this node to be effective.
Particle Radius Legacy, no longer used.
SDF Width The depth in pixels of the signed distance field 3D voxel texture.
SDF Height The height in pixels of the signed distance field 3D voxel texture.
SDF Depth The width in pixels of the signed distance field 3D voxel texture.
Object NodeThe object that defines the emission shape.3D Object
