Trail Emitter
Trail Emitter
Updated: 11 Nov 2025
Emits particles from other particles.
This node emits particles from the positions of other currently active particles from other emitters. This is used to create trails of particles.
This node is typically connected as a child of another emitter node. When connected in this way it emits particles at the locations of those emitted from the parent emitter. Alternatively this node can be connected to a Particle Root node and emitters can be connected to the Source Particle Nodes input.
If no emitters are connected this node is ineffective.
Max Particles Per Source Particle The maximum number of new particles emit per source particle every update.
Use Parent Particle Count Use the particle count of the source emitter to scale the number of particles emitted by this trail emitter.
Use Source Particle Fade Emitted particles inherit the fade values of the source particle.
Initial Velocity Amount Control the velocity particles spawn with in the direction of the source particle.
Initial Velocity Tangent Amount Control the velocity particles spawn with in the direction tangential to the source particle.
Parent Transform Weight How much the transform of the parent affects the transform of the particles.
Parent Transform Weight Life Coeffs How much the particles are affected by the parent nodes transforms at different stages of the particles life cycle. Values 2 and 3 are control points, and are used to control the curve between values
Parent Transform Randomness How much randomness to apply to the parents transform values.
Source Particle NodesThe emitter(s) from which particles are used as sources for the trail emitter.Particle Emitters
