Screen Emitter
Screen Emitter
Updated: 11 Nov 2025
Emit particles from objects within the screen space.
This node emits particles only from objects within the cameras view. Useful for efficiently emitting particles across a large dynamic scene, or creating apparent point clouds from meshes in the camera view. Particles can be emitted from other layers by adding a Render Layer node as an input to this node.
Flip Image Flip the image input vertically.
Luminance Offset Scale Bias the particles in depth by the luminance of the source pixel.
Use Thickness Toggle whether emit the particles on a 2d plane, or in three dimensions.
Pixel Cull/Thickness Mode Change how the depth of the particle generation is calculated.
  • Alpha Channel : lower alpha values will have greater depth.
  • Luminescence : darker parts of the image will have greater depth.
  • Luminance * Alpha Channel : luminance values are multiplied by alpha values and lower values after which are given greater depth.
Alpha Threshold Limit where the particles will spawn based on their source alpha.
Image Colour Adaption How much the particle colours adapt to the image colours.
Particle Use Image Alpha Toggle whether particles use the image alpha.
Emission Velocity Normal Direction How great a velocity the particles are given in the normal direction of the object when spawned.
Limit Emissions Per Pixel Toggle whether the number of particles that can be emitted per pixel can be limited.
Max Emissions Per Pixel The maximum number of particles that can emit per pixels. Only functions if “Limit Emissions Per Pixel” is true.
Emission Area Min Control the minimum area that the particles will be emitted.
Emission Area Max Control the maximum area that the particles will be emitted.
These properties allow the motion vectors from an input optical flow node to move the emitted particles.
Motion Vector Effect Scales effect of motion vectors on the motion of the particles.
Time Offset Offset the time the
Render LayerLayer to render the particles from.Render Layer
Colour ControlControl the colours of the particles on emission.Colour Ramp
