Spline Attractor
Updated: 17 Feb 2025
Attracts particles towards a spline.
This node attracts particles towards a spline shape. The particles will flow along the spline towards a goal point which moves from the beginning to the end of the spline at a rate determined by the Spline Rate parameter. The splines used by this node are extracted from a 3D object which must be connected for this node to have an effect. If The object that is connected contains no spline data this node will have no effect.
This node requires a spline to be connected via the spline input.
| Velocity Amount | Scale the strength of the affectors velocity on the particles. |
| Radius | Alter the outer radius at which the affector is no longer effective. |
| Randomness | How much randomness is added in the particles movement. |
| Spline Rate | The rate at which the goal point moves from the start to the end of the spline. |
| Spline Time Min | The minimum point on the spline at which particles will be affected. |
| Spline Time Max | The maximum point on the spline at which particles will be affected. |
| Life Effect Coeffs | How much the particles are affected by the affector at different stages of the particles life cycle. Values 1 and 2 are control points used to control a bezier curve between values 0 and 3. |
| Object Nodes | The source object for the splines. | 3D Object |
