Rigid Body Collision Affector
Updated: 15 Dec 2025
Allows particle collisions with active rigid bodies.Updated: 15 Dec 2025
Allows particle collisions with active rigid bodies.This node simulates collisions between particles and a Rigid Body Systems.
| Collision Velocity Scale | Scales the velocity of the particle after a collision so they can be made to slow down. |
| Point Collision Radius | Radius around a particle in which it will calculate colliding. |
| Rigid Body Nodes | The rigid bodies to collide with. | Rigid Body |
| Collision Event Nodes | Particle events to be triggered when collisions occur. | Particle Event |
