Primitive Collision Affector
Updated: 18 Feb 2025
Allows particle collisions with simple 3D primitives.
This node simulates collisions between particles and a 3D primitive. It uses ray traced intersections with triangles contained in a bounding volume hierarchy structure. This allows for fast, accurate collisions with 3D primitive, but animating.
Particle Events may be triggered when collisions occur. This allows effects such as particles changing colour, size or material on collision, or emitting new particles at the point of collision.
Particle Collision Radius Radius around a particle in which it will calculate colliding.
Primitive Type The shape in which the particles are affected.
  • Sphere : Particles spawn within a 3D sphere.
  • Box : Particles spawn within a 3D Cube.
  • Cylinder : Particles spawn within a Cylinder.
  • Plane : Particles spawn on a flat, 2D Plane.|
Inverted Invert the object so areas inside the mesh are considered hollow and areas outside are filled.
Collision Event NodesParticle events to be triggered when collisions occur.Particle Event
