Primitive Affector
Updated: 18 Feb 2025
Apply forces to particles from primitive shapes.
This node is used to attract or repel particles from the surface of the selected primitive type. This is typically used to make particles form into a given shape. Particles will use the closest point on the primitive’s surface to move towards or away from; this may be offset randomly using the Randomness attribute to create a noisier shape.
| Primitive Type |
Choose which primitive shape to use.
| Velocity Mode | Control whether the particles should be attracted or repelled by the primitive. |
| Use Colours | Toggle whether to use the colours input by the mesh. |
| Radius | Alter the outer radius at which the affector is no longer effective. |
| Randomness | Applies a random offset to the position the particles move towards or away from. |
| Velocity Randomness | Amount by which the resultant velocity is randomised. |
| Velocity Scale | Scale the strength of the affectors velocity on the particles. |
| Weight | How strong an effect has on the particles. |
| Colour Weight | Controls how much the colour value generated by the affector is blended with the particle’s current colour. |
| Stickiness | Controls how much the particle sticks to the surface of the shape once it reaches it. |
| Life Effect Coeffs | How much the particles are affected by the affector at different stages of the particles life cycle. Values 1 and 2 are control points used to control a bezier curve between values 0 and 3. |
How the primitive colours are blended with the particle colours.
| Blend Mode | Change how the particle affector changes with the particles current changes. |
