Points Affector
Points Affector
Updated: 15 Dec 2025
Uses points sources to disturb the particles.
This node affects particles by positional vortex forces created around points from another particle system, or vertices of a 3D Object. This can be used to make one particle system “move through” another and appear to affect it.
Point Falloff Distance The radius of falloff of effect from each point.
Point Falloff Power The sharpness of the falloff from each point.
Point Source NodeThe source of the point data.Particle Root Node
