Particle-Particle Collision Affector
Updated: 15 Dec 2025
Allows particles to collide with each other.
This node allows the particles to collide with each other while simulating, with a defined collision radius. Combined with the Particles To Point Geometry node, and a similar collision radius/sphere size, it is possible to simulate simple ball physics between the particles.
Particle Collision Radius Radius around a particle in which it will calculate colliding with others particles.
Collision Softening Reduce the impact of collisions between particles.
Dimension Choose whether the effect is 2D or 3D.
Simulation Steps Duration of each calculation step, controlling the precision and speed of the simulation.
