Mesh Collision Affector
Updated: 15 Dec 2025
Allows Particles to collide with Meshes.
This node simulates collisions between particles and a 3D object. It uses ray traced intersections with triangles contained in a bounding volume hierarchy structure. This allows for fast, accurate collisions with 3D objects, but animating, generated or deforming objects are not supported. They may move in 3D space but must be rigid.
At least one 3D Object Node must be connected via the Object Nodes input for this node to be effective.
| Collision Velocity Scale | Scales the velocity of the particle after a collision so they can be made to slow down. |
| Point Collision Radius | Radius around a particle in which it will calculate colliding. |
| Flip Normals | Flip the normals of the input object, so collisions are calculate for other side of the face normals. |
| Double Sided | Calculate collisions for both sides of the objects normals. |
| Dynamic Collision Objects | Recalculate collisions each frame for an animating mesh. |
| Object Node | Object with which the particles collide. | 3D Object |
| Collision Event Nodes | Particle events to be triggered when collisions occur. | Particle Event |
