Mesh Attractor
Mesh Attractor
Updated: 15 Dec 2025
This node is used to attract or repel particles from the surface of a given 3D object, affect them by the velocity of the mesh, or make them flow along the surface of a mesh.
This node is used to attract or repel particles from the surface of a given 3D object, affect them by the velocity of the mesh, or make them flow along the surface of a mesh. Particles will use the closest point on the object’s surface to move towards or away from; this may be offset randomly using the Randomness attribute to create a noisier shape.
This node requires a geometry node to be connected via the Object Nodes input.
Mode The affector mode. attract, particle are attracted towards the surface of the mesh. repel, particles are repelled away from the surface of the mesh. follow surface, particles are attracted to the surface of the mesh and then move across the surface of the mesh once close enough to it. velocity, particles are affected by the movement of the mesh.
  • Attract : Particle are attracted towards the surface of the mesh.
  • Repel : Particles are repelled away from the surface of the mesh.
  • Follow Surface : Particles are attracted to the surface of the mesh and then move across the surface of the mesh once close enough to it.
  • Velocity : Particles are affected by the movement of the mesh.
Target Type Choose where particles move to, mesh polygons or mesh vertices.
Weight How strong an effect has on the particles.
Colour Weight The amount in which the colour of the particles blends towards the target object’s colours.
Stickiness Controls how much the particle sticks to the surface of the shape once it reaches it.
Stick To Surface Distance The distance below which the particle is considered stuck to the surface.
Blend Mode Choose how the particle colours blend to the source colours
Object NodesThe source meshes for the particles ot be attracted to.3D Object
