Force Affector
Updated: 15 Dec 2025
Applies a force to particles.
This node applies a force to the affected particles. This is typically used to give particles a constant acceleration to simulate e.g. gravity.
| Amount | How strong an effect the force has on the particles. |
| Radius | Alter the outer radius at which the affector is no longer effective. |
| Randomness | How much randomness is added in the particles movement. |
| Life Effect Coeffs | How much the particles are affected by the affector at different stages of the particles life cycle. Values 1 and 2 are control points used to control a bezier curve between values 0 and 3. |
| Mode |
Change which kind of force is applied.
| Transform Nodes | Apply the transforms of other nodes to this node. | Null |
| Force Transformer | Transforms the force direction. | Null |
